ust picked up the FAA Part 107 and a DJI
Air 3.
mavicpilots.com
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
Your Drone weighs more than 250-grams (0.55 pounds), and you are required to register your Drone.
Link to the FAADroneZone…
faadronezone-access.faa.gov
Since you live in California, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
44809 is an exemption from Part 107 drone laws. This means that drone pilots fly under Part 107 drone rules by default unless they meet all 9 of the requirements to fly under 44809, the exception for limited recreational operations of unmanned aircraft. You can read more about these requirements...
pilotinstitute.com
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the
Air 3.
After you read all the material, read it again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
At DJI Download Center, Learn aboutDJI
Air 3
www.dji.com
Fly On and Fly Safe…
