For example where a crash happened and the drone can no longer be switched on.
The above is a hypothetical case.
My Experience with the MAVIC 2 ...For example where a crash happened and the drone can no longer be switched on.
I will give that a go, with a new card just for the test i.e. containing a properly stopped test video AND an improperly stopped test video.This is a hit and miss type of situation. Everything on the SD card, EXCEPT the last particular file that was being written should be intact. You can insert the SD card into a Windows PC and it will very likely tell you the drive needs to be repaired. Repairing the drive will allow access to the files on it but there's no guarantee that the last recorded file will be intact and error free.
Those files have not been corrupted at all.For example where a crash happened and the drone can no longer be switched on.
I am aware of that, thanks, but "corrupted" seems to be the common term used to describe their condition.Those files have not been corrupted at all.
They just don't have a proper end of file marker.
Thanks, have you successfully used that yourself?In order to repair the corrupted file, you'll need a working file from the same device.
MP4 Repair Untrunc GUI 0.9.0 Free Download - VideoHelp
MP4 Repair is a Untrunc-w GUI for Windows (frontend, wrapper) which offers access to certain functions of Untrunc - a command line tool for MP4 video repair.www.videohelp.com
Use untrunc.
Yep.Thanks, have you successfully used that yourself?
And the video file header.Those files have not been corrupted at all.
