- Joined
- Jan 17, 2017
- Messages
- 380
- Reactions
- 181
- Age
- 80
I just get a blank calibration screen page on my late 2009 iMac 27". I have deleted and re-installed the app, it's the same result. The video card is 512MB, shouldn't be a problem. I wonder?
Thanks, all! I plugged M into my MBA and had no probs. I'm thinking age of pc is the issue.
I have the 27" model too, perhaps the resolution is too high. I have a second monitor I can try it on too.Actually, I had the same issue on my 2011 27" iMac. The issue is not the age of your MAC but the display resolution, I can't recall exactly what resolution I used but try increasing it and see if that helps, if not, try decreasing it and try again. I can confirm that this worked for me
Thats good news - hopefully I'll be able to finally calibrate my camera tonight tooI just lowered the rez on my iMac and the test pattern showed up! You guys are tremendous!
I still failed to get calibration working on my iMac last night after trying many different screen resolutions. My last option is to remove the external monitors that I have connected and try again. I did however (eventually) get calibration to work on my work PC, so at least I shouldnt get bugged anymore by the calibration warning come flight time.Thats good news - hopefully I'll be able to finally calibrate my camera tonight too
