Hi everoney. Just went over my flight logs and found out that my new battery that has max 10 charges has faulty cell i guess. I didn't notice anything off during flight. Should i be worried? And i do take giod care of my batteries. What should i do?
No i went and check when the drone is on. Says everything ok. Is it posbile to crash with this problem? Why doesent fly app see the problem?Can't really do much if you have a faulty cell, does it show up in DJI Fly as a voltage deviation, if it does the app will eventually pick it up and warn you.
You can keep flying until the DJI Fly prevents you from doing so.
No i went and check when the drone is on. Says everything ok. Is it posbile to crash with this problem? Why doesent fly app see the problem? View attachment 113503
Probably because there is no problem.No i went and check when the drone is on. Says everything ok. Is it posbile to crash with this problem? Why doesent fly app see the problem?
