Received my MA2 Fly More Combo today and noticed something odd with the batteries. I remembered that you should not use the multi-battery strip for the first charge, but when I tested the charge level of the batteries before putting them on the charger they all, all three of them, indicated no charge. That is, when you do a single press of the battery power button it should flash the LED's around the button to indicate the approximate charge level, but when this was done before the first charge none of them flashed any LED's which indicates zero or nearly zero charge. Then, when I put the first battery on the charger the LED's began to flash right away and the initial indication was about 50% charge level or a bit more.
So, that makes me wonder if there is some kind of hibernation mode that the batteries come from the factory in and in order to wake them from hibernation you need to individually charge them (not use the multi-strip). If this is the case then I have to wonder if this hibernation mode can be enabled in some other way such as prolonged non-use and if that happens will you again need to do an individual battery charge.
Lastly, I seem to recall that some here have had to update the firmware for one or more of the batteries but when I powered my MA2 up and updated its firmware I saw no message about the batteries. So, that has me wondering about battery firmware and how to know if they need updating and how to do it.
Brian
Brian
