Battery Cycles
ron77584
What is the most charges you have on a battery?
I have 172 cycles on one of my mavic air batteries but had to retire one after 165 because the voltage was dropping as low as 2.8 volts according to AirData.
Not an Air, but for comparison to other responses....
Of my 5 original M2P batteries I have retired one to ground work (updates, etc) after about 165 hours as I noticed a slight bulge at the end of one flight. The other 4 are still going strong after >175 flights. I fly in ambient temps over 100 degrees F all summer long.
I have 400+ cycles on my Mavic Pro batteries. Sure the flight time is reduced a bit but I still get 17-20 mins per flight. No issues at all. F55485D2-CA88-463E-9284-1C19F929353A.jpeg
I have 400+ cycles on my Mavic Pro batteries. Sure the flight time is reduced a bit but I still get 17-20 mins per flight. No issues at all. View attachment 82123
do you look at voltage graph using airdata? the battery I retired seemed fine but airdata voltage graph showed the voltage dropped as low as 2.8 when 3.6 is normal. I It would be useful to know the average life in # of cycles.
cordilleran
