- Joined
- Oct 12, 2016
- Messages
- 445
- Reactions
- 314
- Age
- 70
Hello BD0G, not sure it's the same issue, there seem to be multiple problems there, mine is all good except with that one battery. Thankfully I have three batteries..Sounds similar to this issue just recently reported Battery error - unable to land - NO RTH - hovering with yellow blinking
Sounds like a bad battery, nothing to do except contact DJI or the retailer where you got it for a replacement.@Alex Baxter I just yesterday was having the same issue while out at a shoot. I have 3 batteries, all new within the last week, and one is showing "Low Voltage" although at full charge. Can anybody help here or should we just contact DJI and send the battery back? Thanks!
Hi Mako79Whats the weather like??
Are you guys keeping the battery in your pants on cold days??
Try discharging the battery by flying it till it force lands. Then do a full charge. This is recommended every 20 cycles.
Hi Mako79
It's not the cold, that would affect all cells equally, I have a low voltage in one cell (ie unbalanced cells) The software will not allow me to fly with the battery in this condition, At DJI advice I've discharged the battery fully (leave the Mavic switched on until it switched itself off (about 3 hours on the kitchen table...) and then recharged it. The error still exists. At DJI request I've sent screen dumps of error messages and battery conditions .
The 'deep cycle' recommendation every 20 cycles has been dropped by DJI, it's no longer a requirement to do this.
Tell me about it.....Thats massive variance.
Send back.
Did you receive a new battery?As I said, we'll get there in the end, it went off to Holland, they've checked it, repaired it (maybe replaced?) and will send it back FOC, I'm expecting it tomorrow. Good for you, DJI. Now the Dutch repair centre needs to have closer links to DJI in Shenzhen, so I don't need this proof of purchase BS. Still, I'm happy enough with the end result.
Hi, I had the same issue. Did DJI replaced your unbalanced battery or after the fully discharge/charge process it came back to life?I did, I certainly did not get the one I sent back..
Sent from my Nexus 6 using MavicPilots mobile app
