Battery temperature
Hi all. What is a normal battery temperature when AC is flying?
the battery temperature during flight will be different each time ,depending on air temp whether you are flying in sport mode or just hovering it will be warm as current is drawn from it and would only get very hot if there was a problem
It also depends on the temperature outside. If you'd like to find the temperature post-flight, you can view your log data with a log view like this one.
Hi all. My battery often displays more than 30 degrees and I get a message with a red point telling me to land quickly because the aircraft is too warm and it can cause problem or something like that. Only me? Sorry for my bad English. [emoji20]
agentsgirl12
