Battery tripped early warning
mig25
I took off with 99% and 11 minutes later i landed because i got the 30% warning. Battery showed one led on the ground. Airdata shows volts and amps for 6 minutes, the data stopped at 50% and no other information thereafter. Airdata on general information shows 11 minutes of flight and landed with 47% battery but i get one led from the battery itself.
Initial Capacity
3486 mAh. At startup
I flew two more flights with different batteries of about 20 minutes each
I have 29 hours of flight shared by three batteries
Anybody else get these conflicting battery information?
I never had conflicting information about batteries. I have 3 batteries and around 100 hours of flight with them (but the last one is new). Anyway rarely I land on with less than 30% of charge.
I got email from dji in 20 minutes
They said it needs to have its maintenance done every 90 days
Run battery down to less than 8%
Then fully charge the battery and check battery status in the app under battery
Mine shows normal
Now i need to fly it and see what happens
Reactions: Maph
Mine shows normal
I've never had to do that with mine, They used to suggest that with the P3 batteries.
Happened to me before. The battery sat around fully charged for probably 2 weeks and then I flew it and one of the cells was low and it tripped the warning. I just cycled it on the charger and it flew as normal next go
dorky
