Are you wanting just a basic charging hub or one that will charge all your batteries at the same time. The ones that @msinger showed above only charge one battery at a time, starting with the one requiring the least amount of charge. There are other models by 3rd parties that charge simultaneously and have a good safety features built on. Down side is they'll be a little bulkier and cost more. Upside, you'll be flying quicker. Another alternative would be something like the Smatree Portable Charging Station. It's WAY more expensive and only charges 3 batteries at a time but, it has something like a 14,000mah battery built in with extra usb port and will charge between 5 and 8 batteries on the go depending on how low you get themFirst timer,
There are quite a few options, so would appreciate suggestions on which hub you think is best, meaning you have used it and it works well.
TIA
The only one I currently have is the exact same one @msinger showed above, just the basic, one at a time charging hub. I have however, been looking into the other ones I've mentioned for quite some time now and will probably be going with this for starters Mavic Air Home Charger to get all my batteries charged plus remote and tablet, simultaneously back at home, and fast. I would also love to have that Smatree portable charger also. Thats what I'm going for but again these are the more expensive of the options. You've gotta choose if you want a basic charger, one that charges everything at the same time for more money, or a portable/hub option for even more money.Are you wanting just a basic charging hub or one that will charge all your batteries at the same time. The ones that @msinger showed above only charge one battery at a time, starting with the one requiring the least amount of charge. There are other models by 3rd parties that charge simultaneously and have a good safety features built on. Down side is they'll be a little bulkier and cost more. Upside, you'll be flying quicker. Another alternative would be something like the Smatree Portable Charging Station. It's WAY more expensive and only charges 3 batteries at a time but, it has something like a 14,000mah battery built in with extra usb port and will charge between 5 and 8 batteries on the go depending on how low you get them
I've been eyeing this one as I really like this guys quality reviews on youtube and he raved about the ability of this for the Mavic 2 Pro, it's supposed to be just as good for the Mavic Air: Mavic Air Home Charger
Here is another similar one on Amazon.
Fstop Labs Mavic Battery Charger
Another alternative would be something like the Smatree Portable Charging Station, Amazon. It's WAY more expensive and only charges 3 batteries at a time, and as bulky but, it has something like a 14,000mAh battery built in with extra usb port and will charge between 5 and 8 batteries on the go depending on how low you get them. Plus you can just plug it in and charge like a normal dock at home. Smatree Portable Charing Station for Mavic Air
Hope this helps.
