Bom Dia from Sao Miguel Azores
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
From R/C and real Airplanes to a Mini 3 Pro
Welcome from the Hampton Roads area of Virginia, USA. I fly a Mini 2.
We have a Member's Map in the Upper Right of the Title Bar, Tap "Members", Tap "Member's Map" Members map
If you are in the U.S.A. there are a couple of Legal Things you may need to do…
Here is a link to flying a Drone in the Azores…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro. You will also find the 74-page Mini 3 Pro's User Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
DJI Mini 3 Pro - Downloads - DJI
Happy and Safe Droning…
Greetings from Birmingham Alabama, welcome to the forum!
Thank You!
Welcome to the forum! :)
JefScot
