'm Mike from Indianapolis. I am so new I don't even have a drone yet!
mavicpilots.com
Mike, I'm glad you wrote you are in Indianapolis, I was going to ask you if "46219" was your Zip Code or your Prison ID… L o L . . .
As a New, Yet-To-Be Drone Pilot, there are a couple of Legal Things you may need to do…
If your new drone is the
Air 3, it weighs more than 250 Grams, you will need to register it with the FAA ($5.00). If you get the
Mini 4 Pro (not Plus…), it does not need to be registered… But in any case you will need to get the TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…).
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
trust.pilotinstitute.com trust.pilotinstitute.com
faadronezone-access.faa.gov
If you are considering acquiring your Part 107 License, here is a link to get you going…
Pilot Institute offers courses on drones and airplanes from world-class experts. Pass the Part 107 or Private Pilot exam and take to the skies.
pilotinstitute.com
Since you live in Indianapolis, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
44809 is an exemption from Part 107 drone laws. This means that drone pilots fly under Part 107 drone rules by default unless they meet all 9 of the requirements to fly under 44809, the exception for limited recreational operations of unmanned aircraft. You can read more about these requirements...
pilotinstitute.com
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the
Mini 4 Pro and
Air 3, including the User Manuals.
After you read the Manuals, read them again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Learn and download DJI
Mini 4 Pro related apps, software, and manuals at the DJI Download Center
www.dji.com
Mavic 3 related apps, software, and manuals at the DJI Download Center
www.dji.com
Fly On and Fly Safe…
