Bug in DJI's fly application
David770
bS
Hi all
When I want to change my code from H.264 to H.265, I only see H.265
I have remove the application from the smartphone and reinstall, this is the same issue.
I have tried to login with a different email account, same issue...
Thanks
David
Which model drone?
Reactions: Kilrah
I was just about to ask that, also when you go back to a different frame rate, it will stick in H265 unless you go in and change it manually back to H264. I'm not certain that it still does that since a couple of app updates but something to watch out for.
Hi all
Thanks
David
Clearly, the app is in the wrong language with too man "é" characters. It's hard to code around that.
D
cbooth
