Buzzing sound from gimbal
DK43
Argentina
It started to do this sound and it makes a lot of vibrations into itself making all the films shaky. sorry for bad english. i would apreciate any help.
Reactions: Cafguy
A big welcome to the forum from the UK!
Reactions: Cafguy
That could be particles stuck in the gimbal. Have you used Canned air to blow it out? DON'T its way way to much pressure for the gimbal, find a compressor and set it really low and then "dust" out the gimbal. After that, Using the tip of you finger gently move the gimbal and "feel" for grit keep repeating until you don't feel the grit.
also check all your screws and mounts and make sure the gimbal is still attached properly to the Drone.
If you have been using canned air you just may have particles that have been blown to deep into the gimble. if that happens it will need to be taken apart and cleaned. (this is why you don't wanna use air in a can)
and Welcome to the Forum from Bakersfield!
It should only be one of the motors, 1axis. One of the motors position sensor is worn out so the motor needs to be replaced. Unfortunately with this drone, all the motors are press fit in so you can’t replace just one motor; you need to replace the whole basic gimbal. This leads to another issue. The drone will need to be reflashed or the gimbal will not center correctly. This can be done with purchasing a license from drone-hacks.com, version 2. Then you can flash the drone with version 1 of drone-hacks. I’m currently going through this with a clients drone. I replaced the entire gimbal. Good luck going down this rabbit hole. Air 2’s have been nothing but headaches for me.
Mavic Air 2 Replacement Gimbal... Amazon.com
Reactions: Cafguy
Badeff
