Cable from the left forward vision sensor is broken
swi
Hello,
I damaged the flexcable from the left vision sensor. Is there a solution to fix this cable or must I buy a complete new vision system?
Best regards
Oh ****. But i thought so. I will order a new one. Thanks for reply.
How did you managed to do that? A crash or DIY repair on the drone gone south?
Did you get a failure notification in DJI GO?
I flow into a tree with sport mode ;-)
The Mavic is a robust drone but the damping board from the gimbal is detached from the mount. So I opend the mavic and fixed the mount.
After I put all things together I noted that i I trapped the cable from the left front sensor and now it is broken.
When I fly, I get a system error and the drone is dithering a little bit.
I don*t know why the drone is now dither.
Maybe I must recalbrate the system.
Or does the dither come from the broken (not connected) front sensor system?
After any good crash, its for sure a good idea to do an IMU calibration.
Reactions: Former Member
Can you post the picture on the broken sensor wire?
hesitantextraneous
