Camera filter PGY issues
MRDI
Is any one having issues with fitting filters to there Mavic cameras.
When i put the filter on it hits the side of the gimbal when it tries to calibrate?
They are PGY filters.
Mine clear the gimbal at all angles. Double check that they are fully pushed onto the camera.
Thanks but mine still hit? What i managed to do was to fire up the Mavic without the filter and once it calibrated i then put the filter on
Reactions: boxsterfahrer
You have to allow the camera to calibrate fully before you fit the filter, otherwise you'll get a "gimbal overload warning' Thus it's the last thing you do before actually taking off, same as on the Phantom
Mine clear the gimbal on initialization no problem. Are you sure they are seated fully on the camera? Also double check that the lens is seated all the way in the frame of the filter. I have seen a few pics of filters with the lens sitting slightly off and it's enough to not allow the filter to sit all the way on the camera.
mine work perfectly fine as well - not sure if they are different??
this is the description that came with them ...
here is a video I made earlier to see if they cause any issue
Buy dji filters . Have to he ok because there designed by dji for the mavic .
I have them they fit like a glove and Come off very easy
Sent from my SM-G935F using MavicPilots mobile app
thinkaerial
