Camera issue
krizzy
Hi, does anyone now why i have this lines in my camera?
They get more profound the darker it gets..
They show up in both image transmission and on sd card in drone.
I have gone thru every camera setting i can think of, also did a drone reset
With dji assistant etc..
No modifications and latest firmware.
It looks defective. There are no camera settings that would cause this.
If it's almost new, then I would return it and buy a new one, if you can. Warranty repair could take weeks.
Well not that new, over a month.. didn't discover the problem at first, only visibly in low light conditions.. now when i look close in a full daylight image i can barely see it, when i now it's there.
Living in north of Sweden, so it starts to get cold as **** here anyway [emoji16] probably not going to fly much..
Looks like a bad connection from the camera to the board that deals with the image.
Could be bad solder joint or a jtag connector/cable is loose. Or even some foreign object/liquid:eek:
Not being familiar with the schematics/internal assembly I'm just guessing, but this used to happen to old Nikon cameras I repaired.
Either way definitely warranty issue
jroy329
