It very well could be the extra weight of the filter, is it more evident when also moving forward at higher speeds like 20mph or greater? The extra weight of the filter plus the force of the wind could cause it to do a "Nodding" motion where it jumps down then back up like you are mentioning.I notice when playing back my videos from the MA there will sometimes be a camera glitch. The camera will blip up for a split second usually when im scrolling the gimbal up during flight. It happens quite frequently. I have a ND filter installed. Could the extra weight make it blip/jump?
Maybe, but why would I be the only one getting the blip when using a filter?It very well could be the extra weight of the filter, is it more evident when also moving forward at higher speeds like 20mph or greater? The extra weight of the filter plus the force of the wind could cause it to do a "Nodding" motion where it jumps down then back up like you are mentioning.
Sandisc extreme 64GBWhat are you recording to? What type of SD card, I had this when I first got my MA but the SD card wasn’t good enough.
What brand filters are you using?Maybe, but why would I be the only one getting the blip when using a filter?
If you had not seen it before, the MA is notorious for the camera blip.
As seen in 1:24 :
I had variable headwinds up to 33mph trying to chase this train down only giving me 10mph forward speed from time to time - average 17mph.
The blip was a gust that increased the angle of attack with the MA nose down.
Filters will not make the camera more susceptible to the blip because the filter replaces the lens cap already on the MA.
Post an example for all of us to be sure.
So is it expected behavior or is it a defect?
