Camera tilts slightly when moving drone left or right.
My first flight with a new MPP resulted in a drastic tilt (like 15 degrees!) when flying L or R. Goes back to level when you stop the L/R. Triggered by slight L R adjustments when flying straight ahead will trigger it. Flying in P mode and at moderate speed. It appears in FPV feed and on the recorded video. Will have to pull up examples.
Even for MP, check that you don't have gimbal in FPV mode but instead in Follow mode. FPV mode is to give you the real feel and view of AC tilt when banking. AC banking occurs when moving right or left but not with yaw.
Reactions: Thomas B
Mine did that. Go into assistant and click refresh if you have current firmware,if update. It fixed mine.also,if you land. And. Reboot Aircraft it might help
Is it this issue?
doaner
