Hi I can’t get the sd card out. Any suggestions. I found a video that sayes you just push on it. I short fingernails. Can I use a tool with out damaging it?
air2" data-source="post: 1104672" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">Yes just be gentle. I use a small screwdriver.Hi I can’t get the sd card out. Any suggestions. I found a video that sayes you just push on it. I short fingernails. Can I use a tool with out damaging it?
air2" data-source="post: 1104672" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">Use the micro card adaptor to remove the card. It has a slanted edge to do just that job. You will be needing it(the adaptor) just after removing the micro to view in your computer.Hi I can’t get the sd card out. Any suggestions. I found a video that sayes you just push on it. I short fingernails. Can I use a tool with out damaging it?
What an ingenious trick that is. It even works on my AIR 1. Unless you try really hard you can learn something new every day!Use the micro card adaptor to remove the card. It has a slanted edge to do just that job. You will be needing it(the adaptor) just after removing the micro to view in your computer.
That's what I use. The MA2 has a fussy card slot, my big fat fingers won't work.Use the micro card adaptor to remove the card. It has a slanted edge to do just that job. You will be needing it(the adaptor) just after removing the micro to view in your computer.
