Can you disable the flashing status light on the mavic
Opfor
Loudon TN
Curious to know if and where you can disable the flashing status light on the rear of the mavic? I really don't need it would prefer to have all the power spent towards flight.
You cannot disable the rear lights. Even if you could disable them, you likely wouldn't notice a difference since they don't use much power.
Reactions: Opfor
There was a thread showing how someone was easily able to rip the leds from the rear bottom circuit board with his thumb nail. obviously it was permanent. I will try to find it.
Thanks but I'm not exactly ready to do something this extreme, was just hoping there was a setting somewhere that I was overlooking.
I understand, as it is damaging and permanent. I just remember reading a thread where the guy said it was surprisingly easy to remove them with thumbnail, he was using it for long range night flying.. yeah, it was too far for me. I have used 2 layers of blue painters tape , and it knocked the rear light down to about 90% just for testing.
That would work, use 2 or 3 layers then Once you get the light completely covered, a very little bit can still be seen through the left and right vents, when its completely dark.
JJustice
