Cannot Enter pano mode
Jean-Claude
Paris
I am newbie, this is my first drone a mavic pro platinium and I try to take pictures using pano mode.
Unfortunately I get am issue when I try the pano mode, after 2 or 3 seconds after pressing the picture bottom I get a message on the controller "CANNOT ENTER PANO MODE"
I did check that I am running last available firmware versions.
I also did a factory reset.
Thanks in advance for your help
Jean-Claude
Jean-Claude
Pano doesnt show up in Sport mode. Do you have enough memory. I have had this occur and its after I used up my SD card memory. Pano and all those cool techniques(horizontal, vertical) use a ton of memory. If you delete some stuff it works again(or put new card in). I have a 128 card but it goes fast when doing hyperlapse, pano, et cetera.
thanks E90RAW
Presently I get a 16 Gb SD card I will try with a larger one,
I replace the 16 Gb by a 64 Gb and it works
Thanks a lot
tortoide
