Can't download h.265 files from internal memory
nodrone4u
Wisconsin
Forgot my memory card. Recorded some sunset footage to the internal memory. It's 4k h.265 and when I go to download it via the app it says I can only download JPEG and h.264. Tried connecting it to my pc via usb-c and it will only recognize the sd card if I insert it. Help! Got some great footage and can watch it via the DJI Fly app, but can't download it anywhere. Anyone else run into this?
Reactions: Ron Boger
I did run into this when I found out I needed a really fast processor to work with h.265 footage. I have used the Sync for DJI iOS app. It supports h.265.
There should be two USB storage show up when connecting the Air to a PC. One is the 8GB internal, the other the SD.
Wait, I thought this was for original Air. If MA2 has internal storage, it should appear the same way.
The internal storage shows up as an unformatted drive on my pc. I can play the footage on my phone directly from the internal storage on the MA2 though.
Solved it! After sleeping on it, I figured I'd test to see if the internal storage was formatted in a Linux format, hence not being discovered on my Win 10 machine. I downloaded and ran Linux Reader 4.5 and BAM! Was able to mount the partition and download my footage. Here's a link to the software I used in case anyone else runs into this issue.
Created a short video in case anyone else runs into this issue:
Linux Reader 4.5 - How to Mount Linux Drive on Windows
RAIJIN
