Capture failed, shooting is currently not permitted.
M.K.Frenky
I'm using Mavic Air. Please help, I'm not able been successfully took a single Panoramic photo with my mavic air, when want to take panorama 360 photo it said "Capture failed, shooting is currently not permitted." and I'm not in Sport mode and l not in individual unlocking zone. What is is issue?
Reactions: JET17 and Piggy
You might have it in sport mode, or the wind is too high, or maybe your gimbal has some dust that's prohibiting movement. It happened to me, I blew some air around the gimbal and did the calibration step, hasn't happened since.
Put a faster SD card in.
Why are you filming at 1600 iso in daylight.? You must love the grain.
Also, never fly in auto or auto WB. Always, always fly in manual mode. Set your ISO to 100!
Can took video 2.7K no issues, normal photo also no issue, only panorama I can't take a single shot.
Even taking with internal storage, I still can't take a single shot.
I'm using latest firmware.
New drone pilot here. What's your reasoning for saying to always fly it in manual mode?
I'll take a shot at that question if you don't mind. The basic answer is to keep a consistent brightness in the recording.
The built in light meter is designed to keep a certain 'overall' brightness in the scene.
Let's say you're flying down a road and the camera is pointed to the ground or trees for example.
If you then aim towards a bright sky the meter will change everything to darker because now the bright sky is taking up a lot of your image and the meter is adjusting to it.
If you see some of the same trees in the same frame with the sky
they will now be darker also and it just gets to look bad after a while because the brightness is all over the place.
If you're flying in manual mode as JA suggests the scene will have a nice constant overall brightness.
There are exceptions to the rules of course.
You do need to figure out what the important parts of your video are and set your exposure to those readings. One way is to point the MP towards whatever is important, if possible, change to manual mode using those settings.
Once again there are exceptions and it's hard to cover exceptions here.
You might want to read up on photo exposure.
Exposure of your video is controlled by ISO, Shutter Speed, Filters-if any, and aperture. If you change any one of those you need to change something in the other(s) to keep the same exposure. I think the aperture is fixed on the MP so you don't need to worry about it.
Hope this helps and isn't way more than you wanted to know....
I never did anything with those, supposedly I'm using auto
1600 is his shutter speed, not ISO! Auto mode can still be useful especially for beginners.
And he was not in filming mode but picture trying to take a pano.
Also as JA suggests 1600 is way too bright for daytime.
Very helpful response. I will now be switching over to manual mode and reading up on ISO, shutter speed and the other photo exposure components to improve the quality of my recordings. Thank you!
Reactions: copterbob
I fixed the ISO error. ISO is ISO whether in pano, still or video. He asked about manual vs auto exposure.
Auto can indeed be useful. That's why I repeatedly mentioned exceptions to the rules.
I did some testing this morning.
I could reproduce this error. The solution i found is as follows:
When your WiFi settings are set to AUTO, i have the above mentioned error. (Shooting not permitted)
As soon i switch to CUSTOM channels, no matter 2.4 GHz or 5.8GHz, i was able to shoot the panoramas.
Sounds strange, but that was what i found out ...
Wow, that would be cool if thats the fix eh?!
But my wifi is custom, i set it 5.8GHz with 149ch. Even i don't use any sdcard only internal memory, i still can't take any panorama photos. I also tried disable all the sensors, still same. Screenshot_2018-02-12-19-58-03-306_dji.go.v4.jpg
Reactions: Chirp
Badeff
