- Joined
- Oct 14, 2018
- Messages
- 121
- Reactions
- 22
- Age
- 43
How does this double storage work? If I put this in my mavic 2 pro seems to record only one picture and not two!
raw + jpeg produces a photo only? I do not see any difference from a picture taken in jpeg ... when I shoot in raw there is also the writing on the pictureNo - it will record a JPG and a DNG.
Let me explain better, if I shoot in Jpeg in dji go4 I see the photo, if I shoot in Raw in the preview of the photo I see the writing in small "raw" ... but I do not understand when set jpeg + raw do not present two photos, but one only, the size of a few mb!Writing? There shouldn't be anything on the picture. The RAW version is just the (largely) unmodified and uncompressed output from the sensor, with greater bit depth than the compressed 8-bit JPG files.
if you look at the photos directly in DJI go4 the photos in raw are marked "raw" in preview! Try !!
reset what I'm sorry?!?On your storage card you'll see two copies of each photo.
One in jpg and the other raw.
If you're not seeing 2 of each photo, try hard resetting the multirotor.
but the problem is not the Sd, I ask because in Dji Go4, in photo mode raw + jpeg I only display a picture !!!!! and not two !!!!You have to pop out the Micro SD card and insert in a card reader. Then bring up the directory named DCIM. Below it there will be files with the extention .jpg and .dng
The files with the file extension .dng ARE the raw files.
That should be a detailed enough response for you to find exactly the files / pictures you seek.
I had read this answer but it is not correct! because the app also shows you the picture taken in RAW and is also marked with a special small writing in the picture "white Written raw ""that's because all you are seeing in the app is a preview, and it shows you the JPG version. "
I think sar104 answered this?
This discussion needs a reset. What, exactly, is your problem?
in fact I discovered it!The dji go 4 app gallery doesn't display both versions of the photo.
