- Joined
- Dec 18, 2018
- Messages
- 69
- Reactions
- 73
The purpose of this link is to show all the arm-chair experts that have told you that electronics and water result in short circuiting are NOT correct.
Later this summer we plan to document a salt water test at the ocean in Main or New Hampshire so stay tuned.
UPDATE from comments/posts provided below:
Here is the link
- Drone electronics are bare NO waterproof coatings.
- Salt water is NOT highly conductive. It is mildly corrosive thus time in salt water is the problem as well as letting it dry which leaves a salt residue that WILL result in problems.
- Had the gentleman with flood issues used the process of washing and cleaning with methanol on all items exposed prior to letting them dry he appliances would have been fine.
- I have a Mavic Pro Platinum that splashed in a lake last fall and did the above process and it is still flying with 100+ hours after event. I did have to replace a damaged gimbals mounting plate that had the rear retaining plastic clip break off.
- One of the secrets is remove power ASAP. Do not reapply power until you are sure it is clean and dry. Bench test without props prior to trying to fly.
Here is the link
