Choppy Video
Martin Wormald
Peterborough, Ontario
When my Mavic is flying straight and level I find the recorded video is perfect. However, as soon as I turn the drone to the left or right, the recorded video chatters or gets choppy.
I would be pleased to hear from a more experienced pilot who may have an answer or suggestion for my issue.
Thanks.
What shutter speed are you using? Much more than double your frame rate (eg. 1/60sec for 4K/30P) and movement will start to look very choppy. If you're flying in auto mode, that could be why.
If you can post a short example to YouTube or similar for us to look at, that would also be helpful.
And welcome to the forum from the land of Oz Martin. Look forward to seeing your work.
Regards
To add to what CanadianDude said:
When you fly straight, things change in small ways from frame to frame. When you turn, the changes can be larger from frame to frame.
A higher frame-rate helps this because you're adding more frames per second of the same turn. This reduces the changes from frame to frame. If you go from 30FPS to 60FPS, you're capturing twice the frames, so each frame changes less from the previous frame.
If you can't (or don't want to) go to a higher frame rate, then you can slow the shutter down to give you image blur between frames. This makes it look more choppy because the brain sees the blur and movement from frame to frame and sees that as more natural, closer to the way we see (or think we see) movement in real life (since our eyes/brain don't see life as a series of sharp, static shots).
And in fact, that last thing is what people seek to do, because it mimics the look and feel of film (old film in a projector going at slow speed, such as 24fps). Use "the 180° Shutter Rule", where you set your shutter speed should be set to twice the frame rate (1/FPS x 2). With a frame rate of 24 FPS, set the shutter to 1/48 shutter speed (or close to it). Or 30FPS with 1/60 shutter speed
1/60 sounds fast, since we can take hand-held shots (without a tripod) with a normal camera and get a good shot, but it's only going to be sharp if people/things aren't moving much.
Hope that helps.
Chris
Hope that helps.
Chris
Thank you for all of that information. I will do some more experimentation with various settings.
I don't remember the shutter speed, but the FR was 24. I have had a couple of replies saying to try a higher frame rate.
I am going to do some experimentation with both shutter speed and frame rate to what works best for my videos.
Thank you very much for your input.
KevinC
