StewartW
Problem? The fan in my Mavic Pro does not run.
Was unit in a crash? yes, received an error message saying the core was getting too hot and noticed the fan was not running.
What have you tried so far? I have replaced it, but it's still not functioning.
What device are you using ( iphone , ipad, Samsung , etc)? iphone
What firmware are you running ( aircraft, remote controller)? whichever is the latest? so maybe V01.04.0300
What Go app version are you using? 4
Any modification? (if so what) none, besides the replaced cooling fan, I also replaced the front right arm and shock absorber.
Did you change anything or install any apps? (if so what) no
Do you have a video or pictures of the problem? (if so post link)
no
NOTE: What confuses me is after I replaced the arm and absorber, I received messages with the core getting too hot AND the front left vision sensor not working. Now that I have replaced the fan, both error messages have disappeared AND my left vision sensor seems to be working out of nowhere but the fan still is not running when I start the aircraft.
Any help is appreciated! Thanks!!
The Main fan doesn't spin up immediately upon power up, takes a couple of minutes for things to heat up inside and kick in the fan...
dvkhamtruocsinh
