Correct DJI assistant for Mavic 2 Pro?
justcruisin
USA
So I was troubleshooting on an Air 2 and I think I overwrote the files I had with the correct version of assistant for my Mavic 2 Pro.
So where do I find a way to download the correct version of assistant for a Mac and a Mavic 2 Pro on firmware 01.00.0770 ?
Thanks in advance
or is it now just V 2.1.34 for Consumer Drone Series?
You should install V2.1.30.1 from the "Parameter Adjustment Software" section at the link above.
Thanks in advance
You may be looking for DJI Assistant 2 v.1.1.2. This is the version where the developer module can be activated by altering the values in a couple of lines of code (pretty straightforward procedure).
It is possible to find this version if you search specifically for it... just be careful about some of the sources.
For example here: DJI Mavic 2 Accessories & Tips | Mavic Help - mac and windows version available.
A very safe source :-)
I used that version to alter parameters on my Mavic 2, to replace sport mode with ATTI mode.
Reactions: Felix le Chat
Thank you everyone.
I will read all the release notes and figure out which one is best for my situation.
I just need to recal the vision sensors every now and then.
My M2P functions fine on the firmware version it’s on and I want to keep it that way so I never update anyway. Not really looking to alter parameters or anything.
DayTrip
