Hello, I crashed my MM into a small branch a while back. Upon inspection I noticed the lens had separated ever so slightly from the housing. It all worked fine so I thought Ok, live and learn and be more careful. When flying over the weekend I was RTH and realized that lens is out of center with where the drone is headed. For instance if i was at 12 o'clock the lens was facing 11 o'clock. Because I'm a genius, (place chuckle here) i decided to push the lens back into the housing. Since then I keep getting a gimbal error 40002. When booting on the gimbal does it's thing but then the lens points up above center instead of level. If i flick the lens and housing it eventually will work but the lens won't point straight down and it will occasionally bounce like it wants to go down but it won't.
Any idea how I can fix my stupidity??
Thanks!
Thanks!
