Crashed mavic 2 pro - gimbal rigid at bottom tilt
frlipesalomao
Hi, my drone fallen From Balcany, 30 meters down when I was take off.. It had some kind of problem that even on full throttle, It not gained altitude.. I think was some vision sensor problem.. As I do it over 6 month (about 300 times) and never had problem before.
But, let's focus on gimbal problem after crash.. Just had 2 damages (2 props changed, and gimbal).
Gimbal is rigid between 70 to 90 degrees tilt down. how much further down, more rigid.. So, tilt works well until about 60 degrees down.. If I go further, it could freeze and not come back more.. If I squeeze in both laterals (where has tilt motors), unblock complete tilt moviment, so it works fine event between 70 to 90 degrees Down.. Once I release my fingers, it become rigid again.. I tried use sewing thread to "clean" space between sides motors and camera body.. But still having problem. At beginning it was worst as it showed overloaded gimbal.. As I "cleaned", it got better.. But only in this final course, I could not make it better.. Any tip? I think unmount ii it's near impossible.. As this place I am talking about is Like glued or something else, as it not use screws (I think so)..
Rckern85
