CREE - red/green Strobes
Bobby Brown
Gun Barrel City, Texas
Received my CREE Strobes. They are blinding when activated! I now pre flight cover each with half a posted note. Activate prelaunch, activate battery turn head and pull off posted notes. Move to my safe launch distance then I’m off!
They are excellent at my flying heights
Highly recommend
Drone on.........
Highly recommend
Drone on.........
What ones are more noticeable while in the air Bob, I can see my red leds more than the green ones.;)
Reactions: crlmjohnson
Reactions: BD0G and msinger
Had red on the bottom and green on top. I’ll swap and let you know. Been raining here for three days
Thanks bobThumbswayup just interested because my standard red LED’s do seem more noticeable in the dark than the green ones, it might just be me though;)
Reactions: Turn11
For your reading pleasure, here is the information on which color strobe is the brightest and least bright. About two thirds of the way down is the heading appropriately named Which Color is the Brightest. Hope this helps and I can verify this from my many years in the US Navy Submarines.
Reactions: Porky
Thanks for the info, so my eyes are right then, red then green;) before you jump on me.... I know it does say “white” first but I only wanted to know about red/green cos that’s what I see all the time on my drone while flying dusk/dawn.;)
Flew last night put green on bottom red on top. I’d say red is more noticeable
I could see green to 550 feet. They did look rather cool cruising by at 400 feet in height or so and around 300 feet in front of me
I think the red and green are needed by 107 guys to meet code for night flight and sight distance requirements
Flew 2 hours total yesterday sunny. Blue skies and no wind
Drone on..........
Reactions: BD0G and Porky
The FAA has no color requirements. The aircraft just needs to be visible from at least 3 miles away.
Drone on..........
Thanks bob, I could definitely see a big difference between the red/green leds that are standard on my drone. Red far more noticeable.
Thanks for coming back to me about it, looks like I need to invest in some now;)
Picked up this one... OMG I popped it on the bottom of my Evo and I can see it a mile away!
That's great but the requirement is 3 miles. Just sayin'.
Those lights can be seen from 3 miles away too. They use the same Cree lights as STROBON Cree lights.
Reactions: DavidNDC and Turn11
Put the brightest white one on top for other aircraft to see, red and green are typically for navigation and go on the sides- remember the waiter says the only wine they have is “red port left”. I put a weaker white on the rear, too. This configuration makes it easy to see which way the drone is oriented and direction of flight. It also gets a lot of attention whenever I turn on the landing lights at altitude, too.
Its fun trying to turn them off as you are being blinded, isn’t it? :)
Yeah, makes me miss the days of setting my own receiver up and being able to control axillary devices with a switch on my futaba.
I bought same brand red, green and 2 whites. Used the great mounts from Aerial Pixel. Mounted the as on full sized aircraft. I can easily see the bird at 2.5 miles out. I’m sure the STROBON are just as good... and look very similar. I’m gonna try that postage stamp trick or maybe some occlusive tap with poor adhesive. Great idea you gave me!
Reactions: Bobby Brown
Crapaw
