Definitely a neophyte.
Ticoviejo
Florida
Got to watch one of my nephews flying an Avatar about 4 weeks ago in Costa Rica. Needless to say, the bug bit me. Since I didn’t want to take unnecessary chances, I ordered the DJI Mini 4 Pro because of the Omnidirectional safety features.
My biggest surprise was it showed up yesterday P.M., only 6 days after I ordered.
I had signed up to this site, and have been doing a lot of reading.
Thanks.
Keep reading, ask questions about anything you even think you do not understand. Low and slow at first in a safe area, with no trees, people or buildings.
When you encounter a behaviour you did not expect re read the relevant section of the manual.
Above all, work through ALL the RTH behaviours especially distance related RTH behaviour.
If relevant did you pass the trust thing etc. etc. ?
Welcome.
What's a neophyte :D ?
Thanks.
Welcome from the middle of the U.K.
There is ALOT of good knowledge and member's here!!
There pay check?
Helping others, learning from posts. I guess that's why I'm here.
The Mods keep it clean? I can't think of a better term.
BTW, Welcome to the Forum!
Rod ...
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Florida, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum from the beautiful woods of Maine!
There’s many knowledgeable members willing to help you with any questions you might have. Search the forum using keywords and if you don’t find an answer, post your questions and I’m sure you’ll get a quick response! Fly safe and stay safe!
LoudThunder, thank you very much for taking the time and explaining to me all that info.
I did get a pilot’s license back in the late 70’s. Fixed wing 150-172. I don’t recall it being so complicated. Times have changed.
I followed your advise and got the “Trust” certificate. It’s somewhere hidden in my iPad. I’ll find it and take a screenshot of it to have handy.
I depleted one battery just filling in the safety parameters for flight in the RC-2. Then I took off and landed twice. One trip went as high as I could see(43m) and about 150m away over the trees.
Thanks again.
sscott062
