Its all in the user manual & discussed in several threads on here.The batteries in question have 3 to 4 lights on, I think letting them sit idle for 1 or two weeks with full charge is what worries me, and I'm storing them in a GPC case with the foam which I would think hold the heat in a bit more than sitting on say a table in the open. Are you saying that a fully charged battery will discharge itself to a point of hibernation without outside input? It seems like that would take a very long time and I worry about case fatigue.
Thank you very much OMM.the storage level that DJI bring them down to is perfectly fine for long term storage ,its more to do with individual cell voltage ,and making sure you check them monthly and top them up to around 60- 75% if they need it
60% is marginally less optimal than 40% but a lot better than close to, or at 100%...... Probably not enough to worry about.I've seen opinions that the 60% discharge is still to high and that 30% is closer the the ideal point of storage. But as you say the manual states 60%. What do you think about the numbers? (thank you for the reply)
