DJI Air 2S for High-Resolution Photogrammetry - Seeking Advice
ani_rec
Tirana, Albania
Hello MavicPilots community,
I'm working on a research project that requires creating a high-resolution 2D map of an area to study a flowering species. We need to achieve a ground sampling rate of less than 2 sq cm per pixel, which means flying at a low altitude.
Our budget is limited, so we're considering using a DJI Air 2S instead of a Mavic 3 Enterprise. I'm aware that the Air 2S lacks a mechanical shutter, which could be a concern for this type of work.
I'd greatly appreciate your insights on the following:
1. Has anyone used the Air 2S for similar high-resolution mapping projects? What were your results?
2. How significant is the impact of the rolling shutter on image quality when flying at low altitudes?
3. Can the Air 2S, when paired with photogrammetry software (like DroneDeploy or others), produce sufficiently high-quality maps for our needs?
4. Are there any specific settings, techniques, or third-party apps you'd recommend to optimize results with the Air 2S for this kind of work?
5. Given our requirements, would you advise making compromises elsewhere in our budget to afford a Mavic 3 Enterprise instead?
We're open to using various software solutions, so any recommendations on that front would also be welcome.
Any suggestions, recommendations, or feedback based on your experiences would be immensely helpful.
Thank you in advance for your expertise!
What kind of altitude are you thinking you'll fly at?
How low is low?
How tall is the plant species you are working with?
What area are you wanting to cover?
Others have used the Air 2s.
These might be helpful:
Perhaps at low heights ... a little testing should give you an idea.
See the links above.
DroneDeploy
According to the DD website, the Air2S only works with the iOS version of their app.
No ... the Enterprise model is overpriced.
The Phantom 4 pro or P4 pro V2 are very good for photogrammetry and have mechanical shutters.
Note .. you cannot load DroneDeploy on the integrated screen controllers
Wish I could help, but I have no expertise...
Welcome to the forum. We look forward to your participation and your view of the world.
RobertCNewman
