Hello,
Anyone made a debug mode for 1.2.5 or close version. I need to take my mavic air battery into NON-DJI battery mode.
Thanks.
You got it. I would only recommend using 1.1.2 for changing the aircraft settings. The other available features might not work as expected.You may not be able to update the firmware with 1.1.2 but you can put it debug mode and change those things.
i am unfamiliar to non dji battery mode?
is it for specialized application?
also, the old asst2 can prescribe mavic air feature behavior?
windows10 can not allow both versions installed but utilized singularly?
i mavic air fly with vision disabled (night and underground bunker). old asst2 may allow disabling mavic air defaulted features not needed conserving energies. thats why i was trying to rollback ALL SOFT involved with mavic air to beta testing era prior to debut 23january2018. all thats necessarily needed is perfect camera, flight time, pilot expertise, so simple. the bells horns and whistles can be forfeited rolling back to olden soft.
brett, we're relaxing instructions demanded per unit time, of the microprocessor, termed flight controller, in turn relaxing sub modules, the esc, the intelligent battery, and visionary sentinels. in underground bunker flying, dont i want exp/gain lowballed and brake factory default? brake relies upon down vision (fwd/aft vision disabled) contingent with discrete ground recognition and illumination. but asst2v1.1.2 gangs ALL visions off take it or leave it? otherwise stick training for stick braking would entail "learning all over again", or stick braking is intuitively learnable in a jist?
1.1.2 is to disable features un-needed, saving battery, funneling focus on camera and journeying.
with conditions yes and no light, yes and no gps, no vision fwd aft,
its wise desensitizing sticks, essentially flight control, and owing to inertia, keeping brakes. brakes derived comparing ground vision works sufficient lighting and counterpart gps works nites days
I downloaded and installed V1.2.5 from the DJI site because it is the most current version; is there a problem using it for my Mavic Air? Can I put it into debug mode in the same way as for v1.1.2?You can use debug mode in DJI Assistant 2 version 1.1.2.
No. DJI patched that hole in newer versions of the DJI Assistant 2 application.Can I put it into debug mode in the same way as for v1.1.2?
I find my Mavic Air is too sensitive in yaw - that is, it takes very little displacement of the stick to get rapid yaw motion - I'd like to still get the same max yaw rate (with max stick), but I'd like to bend the response curve to let small movement of stick result in lower yaw rate. I am aware of Tripod mode.I can’t understand what you said, I’m sorry. Don’t hesitate to use google translate if you need to.
If you are far enough underground that there’s no chance of GPS reception then you don’t need to do anything. Your Mavic will automatically switch to opti mode if there is enough light. In which case the brakes will still work. If there isnt enough light the brakes will not work.
Don’t mess with the ESCs. They can’t be modified easily anyway. If you just want the reaction of the aircraft to be slower then you can adjust the braking sensitivity and attitude sensitivity in the DJI GO 4 app. You do not need Assistant 2 to do that.
Main controller settingsI find my Mavic Air is too sensitive in yaw - that is, it takes very little displacement of the stick to get rapid yaw motion - I'd like to still get the same max yaw rate (with max stick), but I'd like to bend the response curve to let small movement of stick result in lower yaw rate. I am aware of Tripod mode.
That’s why I keep my sport mode sensitivity higher than my P-GPS sensitivity. That way if I really need to turn quickly just switch to sport mode and then when turned switch back to P-GPSWe're talking stick desensitization here.
I intentionally prescribe all to lowest allowable numeric.
Drone acts lazy sluggish sloth
It can become unuseful in event spiffy immediacy is urgent to arrest craft motion.
Also, be very aware inadvertently touching screen graph because it reassigns another numeric, opposing your desire, while you're unaware it actually changed numeric
Got it, sport preset for arrest response, by mere switching of sport mode switch off (position mode) and onThat’s why I keep my sport mode sensitivity higher than my P-GPS sensitivity. That way if I really need to turn quickly just switch to sport mode and then when turned switch back to P-GPS
