DJI Fly app not updating battery firmware.
thesotman
Hi,
After updating firmware successfully for the drone and controller for the first time.
I can't update the battery's firmware, after swapping the other batteries.
Please help, thanks.
@thesotman ,not every update has a battery update included ,it depends on what the update was for when you put another battery in the drone then it will only ask you to do a update if one is required,have you tried to fly the drone with a battery that was not in the drone during the update
It flies fine, no problems.
Most updates won't update the battery. Unless it says it's updating batteries, no reason to expect it update other batteries. The App will tell you if the batteries are not on current update that requires it.
4f4l4m
