Do you use more than one device to fly? Sometimes it will break up your flights from one device to another, especially if you have the aircraft bound to one device for the "flyaway coverage".
Seems very odd. Did you try syncing your flight records? I have seen cases were the numbers some numbers are off and syncing helps, but per MavicAir2Mark, that is usually due to a new device or new drone.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
