hi all I've got the fcc mavic mini in the UK so it drops down to ce power normally I use the fake GPS and get fcc that way.
Today I thought I'd try the drone hacks mavic mini boost hack.
If anyone out there has the same do you just use the boost can connect like normal or do you use the boost hack and the GPS fake hack take off and then connect.
I'm still trying to understand this
For the Mavic Mini Boost mode, there are no specific mW values, this will boost your Remote Controller output to the maximum possible for your specific hardware. Due to regional hardware differences in place on the Mavic Mini by DJI, the results for maximum boost mode mW transmission power will be different on CE and FCC models. However: Tests showed that boost mode on the mavic mini will currently NOT give you as much power as if you use fakeGPS before every flight, we are working hard to see if it is possible to reach the same power levels persistent without the fakeGPS trick.
Does its mean a fcc controller in a ce country will get the full ce country power plus a boost
Or will the boost give the fcc power even when set to a ce country.
