Mavic 3 Pro (+FCC hack) and 4G dongle
the dongle 4g is only enabled on the last frimwear? on my mavic 3 the frimewear is 01.00.1000 for work with fcc mode and i doesn't want to upgrade to the last fw for test because after with the antirollback i can't return to the back version :/ but my rc pro is on 0700 maybe i can update mavic 3 to latest fw and setup fcc mod on my rc pro for enable fcc + dongle?
Does not work atall on 01.00.1000 ino this because I had it also 03.02.0700 will not enable the 4g it has to be 03.02.0800 or 03.02.0900 on the rc pro aswell as latest firmware on the mavic 3 and to answer your question you can download latest mavic 3 firmware using drone hacks
i have reset to stock my frimewear and i have the same message... not allow in you location... i don't understand why...
Will not work on firmware lower than the latest firmware on the mavic 3 and needs latest on rc pro installed
hello thank's for your reponse.. i have understand the fcc hack is not good with dongle 4g so i have flash the frimewear to stock and disable fcc because in us dongle is disabled... but now i am stock and in france dongle is now recognized because the serial number is valid but i have the same message "transsmission enhanced not avalaible in your located" i don't understand why because i have disable fcc
ouk i have understand only the last frimewear is ok with the dongle... but if i flash the last frimewear i will never comeback to the 01.00.1000 and i lose my fcc for ever :/ because my fcc lisence only work on 01.00.1000fw and anti roll back disable downgrad... :/
You can definitely downgrade firmware from latest 1500 to 01.00.1000 using the drone hacks tool it definitely works as I have used it for it
Reactions: lockers86
you have drone hack and test fcc is ok with the 01.00.1500 ? and after i can disable it just on rename CC UK ? it's that?
With 01.00.1500 you need the fcc mod from the Chinese on the rc pro you need 03.02.0700 to install it first time then after the rc pro can be updated to latest firmware
unfortunately dji's anti roll back does not allow you to downgrade to all versions but remains on the same arb value for example if 3 frimewear have an arb value 3 it is possible on the other hand if they go from a value 4 to one frimewear value 3 it's impossible I've already tried with drone hack it's blocked...
that's why I would like to be sure that the dongle works with version 1500 because after that I definitely won't be able to go back...
maybe it's possible with a commande line and Fcc mode to enable fcc china for exemple rename mavic CC JP you think that work?
I have receive a message from dji the dongle 4g for mavic 3 is disable out of china :/ wath is your country please and you dongle 4g at this moment on your country?
Is definitely working outside of China my country is united kingdom CC JP,CC RU,CC US blocks 4g CC HK, CC IT ,CC CN those 3 enable 4g but not that to work you must have the fcc mod patch installed on the rc pro
I just want to be able to switch between FCC mode and deactivate it to switch to 4G mode if necessary without having to reflash the showoff every time because if I deactivate FCC logically I go back to my original location, which is France, so it should work. ... I read a command on drone hack apparently to deactivate fcc mode
are you her my friend? i'am now on the last frimewear on mavic 3 and rc pro and the dongle work perfectly... but i would like to enable fcc with dongle it's possible?
dentec_jc
