4G dongle Mavic 4 in EU
Status
Not open for further replies.
my DjiFly app is 1.17.1 and 01.00.0100 for Aircraft Firmware and 01.00.0100 for RC Firmware,how do i downgrade? my dongle will arrive in 2 days
You will be able to downgrade the drone and if that is the RC 2 and not the RC Pro 2 then you will be in luck. Download the Drone Hacks V2 windows application from the first link below, ensure your PC has the latest Dji Assistant 2 for Mavic 4 Pro installed and it can detect your drone, then close Assistant 2 and open the drone hacks app, connect the Mavic 4 Pro using the Dji USB C cable and proceed with FW Flashing.
You will need to download the FW from the second link which is Dankdownloads.For the RC 2, you don't need to do anything.
Reactions: arslansinan
Ho aggiornato l'app Fly sull'RC Pro 2 alla versione 1.17.0 e il 4G funziona ancora. Non voglio rischiare di provare ad aggiornare l'RC al firmware più recente perché ho provato Drone Hacks e l'RC non viene riconosciuto affatto. Per ora funziona, quindi lascerò così finché non sarà completamente disponibile al di fuori della Cina. Chiunque voglia far funzionare il 4G sul proprio RC Pro 2 dovrà trovare un modo per effettuare il downgrade; se state aspettando il nuovo firmware, non aggiornatelo. Scaricate l'APK Dji Fly 1.17.0 e installatelo manualmente, non aggiornatelo tramite l'RC Pro 2.
ciao ma cambia poco ti chiede un aggiornamento forzato quindi con quel firmware non puoi usarlo hai gli stick di comando bloccati. quindi serve a poco.
I updated the Fly app on the RC Pro 2 to V1.17.0 and 4G still works. I don't want to risk trying updating to the RC newer FW because I tried Drone Hacks and the RC is not recognised at all. So far it works so will leave it as that until it's fully opened outside of China. For anyone who wants to get this 4G working on their RC Pro 2 then you will need to find a way to downgrade it, if you are waiting on your new one to arrive then don't upgrade it. Download the Dji Fly 1.17.0 APK and manually install it, don't upgrade it via the RC Pro 2.
Is the drone flyable like it how about the rc firmware update required message in the top corner doesn it stop the motors from starting post a screen shot in flight if you can please
You may try, but @Suren and me have tested a period and the dronehacks software isnt detecting the rcpro2 - you will get an error. So at the moment, downgrading is not possible.
But feel free to test and share your results.
At the moment:
Dongle V2 4G ONLY works with Mavic 4 Pro in the next ways:
Drone:
Mavic 4 pro needs to be on 0000 firmware, 0100 needs to be downgraded to 0000 (fabric version)
RCs:
It works when:
RC 2 with current firmware
RC Pro 2 only with 0000 (downgrading is NOT POSSIBLE till now)
Hope this clear anything out
Al momento:
Il Dongle V2 4G funziona SOLO con Mavic 4 Pro nei seguenti modi:
Drone:
Il Mavic 4 Pro deve avere il firmware 0000, mentre quello 0100 deve essere declassato a 0000 (versione fabric)
RC:
Funziona quando:
RC 2 con firmware corrente
RC Pro 2 solo con 0000 (il downgrade NON è POSSIBILE fino ad ora)
Spero che questo chiarisca qualcosa
rc pro 2 non funziona nemmeno se si esegue il downgrade. Richiede un aggiornamento forzato.
Questi sono i fatti.
non permette di far funzionare i controller stick i pulsanti sono bloccati,
It will work when the Mavic 4 pro also is downgraded.. then both versions are compatible to each other
Do you have a picture in flight with 4g working on rc pro 2 and mavic 4 pro
No, i don't have because i can't downgrade the RC pro 2 firmware. Forum member Suren have it working, see several messages up for this. I just copy that messages.
I have tested it with the latest fw on RC2 and that worked well, even with the Mavic 4.
Lies, but I wonder why you tell all these lies. We tried, but it doesn't work, so don't talk nonsense.
Mate, I have it working. I posted screenshots and it works. Done a very very long flight on 4G only and it works. If you don't want to believe then that's on you. We don't have to prove anything further and have nothing to gain. We are just trying to help others.
Status
jwright17
