Old beat up farm jeep then right next to it.What is a safe distance from your automobile to take off with your drone?
Are you asking in order to prevent compass interference? If so, 6+ feet would be sufficient.What is a safe distance from your automobile to take off with your drone?
YMMV
I'm sorry What does "YMMV" stand for???YMMV
LMGTFYI'm sorry What does "YMMV" stand for???
YMMV
Thanks that helps a lot.
"Your Mileage May Vary"I'm sorry What does "YMMV" stand for???
No answers?Looks like you got some smart-donkey replies but no answer.
There are plenty of cases where magnetic interference was not enough for the app to give a warning but the steel close to the compass causes serious impacts.Go 4 should inform you about magnetic interference if there is any. I routinely launch ~6ft from my car.
No answers?
Except for post #10 (as confirmed in post #11).
Like I said, it should warn you. If there is enough steel to cause serious impact it should warn you. Best practice is to launch away from ferrous metal, check that the Mavic and Go 4 indicator are pointing in the same direction, insure good GPS reception, confirm the home point on the map, and hope it all works.There are plenty of cases where magnetic interference was not enough ....
