Drone totally broken after firmware upgrade
elpimps
ita
This is an old problem but only today i decided to investigate more into this issue.
Long time ago i upgraded my mini (1) to 0600 and suddently it stopped working.
When i turn it on and sync with my RC i just cannot move the camera up or down BUT if i get into manual gimbal setup, i can move the camera with the arrows.
I think that, for some reasons, 0600 is incompatible with my drone but for obvious reasons, now i cannot downgrade it to any previous versions.
Any help?
Edit: there is a "fake" method that is going around in the forum to downgrade the firmware
i debunked it here with all assistant 2 consumer versions: Mavic Mini 1, can't downgrade from 01.00.0600
So i suppose there is no way to get back and fix it at this point...
Dunno if i'll buy a dji again
I don't recall ever hearing of an actual case of a firmware upgrade creating a problem like that. It's almost certain that there's another problem.
You might try re-installing the Fly app and refreshing the firmware. It's possible that the installation of the upgrade was corrupted.
I already tryed all possible solution from the web. The only thing i cannot do is to downgrade the firmware to a working one.
The drone stopped working just after the update.
iOS or Android device hosting the flight app? If android: use an older version of the FLY app and try connecting again.
marcusjohn3684
