Great fpv! Thanks What settings are using to get such nice smooth coordinated turns?
I can't remember, but usually, I use strong bank auto coordinated turn as low bank has some bugsGreat fpv! Thanks What settings are using to get such nice smooth coordinated turns?
I don’t understand. What do you mean by “strong bank auto coordinated”? How does this translate to the settings’ numbers? Thanks for any more clarification you can provide.I can't remember, but usually, I use strong bank auto coordinated turn as low bank has some bugs
Dji fpv has a menu item coordinated turn with 3 option none, smal and strong bank, whatever you chose it perform auto coordinated turns in S mode (puting bank to yaw) and you can change this midflyght with c2 (i think) button. If you chose none you can do them yourselfI don’t understand. What do you mean by “strong bank auto coordinated”? How does this translate to the settings’ numbers? Thanks for any more clarification you can provide.
Thanks. I never noticed that feature and have only been experimenting with the manual settings.Dji fpv has a menu item coordinated turn with 3 option none, smal and strong bank, whatever you chose it perform auto coordinated turns in S mode (puting bank to yaw) and you can change this midflyght with c2 (i think) button. If you chose none you can do them yourself
I had M only once as it requires mastering and I am on some beautiful spots filming... Might be some day I'll master it enough to film something, for now S is doing the trick for me (bringing wide format vision with speeeeeeeeeeedThanks. I never noticed that feature and have only been experimenting with the manual settings.
