EMI canceling / shielded landing pad?
Your response back in post #5 indicates that you have a very poor understanding of compass calibration does.
The video you just posted has more misinformation.
I'll suggest again that you need to read the first post in the thread I linked to get a proper understanding of what compass calibration actually does and when it might be required (almost never).
The video says that if you move more than 50 miles from the last flight (which I've done 6 times) or more than 1000 feet of elevation (which I've done 4 times) then calibration is recommended.
It's recommended to do it before you get the warning.
I have received the warning.
Both of those seem to counter what you are saying but I understand that you can't change your mind.
Your video says those things and they are completely wrong.
Whoever that video guy is, he's not someone you want to pay attention to.
Recommended by some misinformed video guy who has no idea what he's talking about.
And you misinterpreted it.
I explained what your compass was warning you about.
I can't tell what you are trying to say here.
But I can tell you that you have some screwy ideas about compass calibration and have been fed a load of misinformation.
Now get some factual information and read the first post in the thread I linked.
Reactions: waynorth
Mine has asked
There are several notices that DJI inserts in their apps that the ignore button is the better remedy. I’ve always thought they were there as a CYA(cover your _ss)item that many manufacturers utilize merely for their benefit. Some of these warnings are somewhat annoying like the one that warns the drone is exceeding the 400 foot limit as I fly up the side of a 6000’ mountain ridge.
I have several Mavic 2 drones. Most of them never asks for compass calibration unless I power up the drone close to iron, and even then the message is wrong. As Meta4 explains, it does not need calibration. You need to shut down the drone and move it to a place further away from iron/metal that can affect the compass.
A better way to check if you are too close to metal is to go into the Go4 menu and find "sensor state". Here you can see if the compass is affected by metal close by. A green bar means the compass is fine, no matter what the on screen message says.
On every startup you should always check that the red arrow (your drone) in the map or radar display always points in the same direction as the nose of your drone. This indicates that the compass is good.
Now, some (not many) Mavic 2 drones has a software glitch that gives the "calibrate compass" message almost every time you turn it on. I have one of them, and it is a false message. I check the sensor state and it is OK. I take off, and it flies perfectly fine.
These tips will keep you safe:
If the compass is biased by a ma
Thanks all! Great discussion.
I do like the idea of powering up the drone outside the truck and waiting for gps lock, then placing it on the roof / hood / bed. As @KB9Radio mentioned, I've had interference issues from both concrete pads and gravel parking lots, so holding it while powering up should totally work in this situations as well.
For that matter, at that point I suppose I *could* just hand-launch it...as I've been reading thru this thread it occurs to me that I'm more "ok" with hand launching it than I am with hand-catching it. And as was also mentioned, I've not had any interference issues when landing it, and I have actually landed it both on the roof and in the bed with no issues.
So looks like I'm going to try hand launching it and then landing it on / in the truck and see how that goes. I'm still going to get a heavy mat to land on so I don't scratch up my truck, but it won't have to be a "shielded" mat.
If the compass is biased, hand launching won't help.
I don't see any concern about a drone scratching anything when it lands. Never had an issue with my car. Stick a cut down felt furniture pad on each leg if it's a big concern for you.
The purpose of hand launching is to ensure the compass remains unbiased. When held at should height or above, that's normally high enough to keep it away from all nearby magnetic metal sources.
After the drone has been started without compass bias (by holding it waist high), is it not possible to then place it near ferrous material without an issue? That seems to have been my experience
I haven't tested that myself, but I wouldn't chance it when in a location where there's known interference since it's easy to hand launch.
Yes, that is also my experience. Only during startup it needs to be away from metal.
Reactions: MS Coast
I tinkered quite a bit with starting a Mini 4 on the hood and roof a car, and near and on top of a large iron spike. Startup seemed to be the critical period with respect to compass bias.
Regardless of the launch location or method, I always confirm that the compass agrees with reality immediately prior to takeoff.
Reactions: msinger
What happens when you place the drone near an area of interference after starting up? Does the compass agree with reality?
Yes. There's a spot on my patio where compass bias occurs if I start the drone sitting on the concrete. If I start it while holding it at waist height and then place it in the same place, there's no issue. I found the same result launching from one location on the car roof.
Reactions: msinger
Good to know! I was thinking the direction might remain skewed until the drone is several feet away from the interference.
I don't know if this would work, but I have been toying around with the idea of a shielded landing pad. I was thinking about making a diy pad or using a store bought one and putting RFID Anti-Magnetic shielding fabric on the bottom of the pad. The stuff is really cheap, comes in a roll, supposed to block EMF and EMI.
My issue is I defiantly do not want to launch by hand and I live in a big crowded city where every surface is man made. The only places I have to launch from are big space for pubic use like those on top of a parking garage. Concrete and rebar, metal pipes underneath as well. Even the benches are concrete with rebar. The grass area is on top of the garage which is concrete as well.
I've been able to avoid the problem with ferrous materials by holding the drone waist high when I power it up. The usual launch location on my patio creates a problem, presumably because of rebar, but I'm able to stand in the same place and start the drone with no compass bias.
I'd like to launch/land my M2P from the top of my truck cab (or the hood, or the bed), but whenever I power it up on any of those spots I get a compass error. If I just move it off the truck, the error goes away. I've also found on one construction site that the ground itself had so much interference that I got a compass error.
Is there such thing as a heavy (so I don't need to weight it down with rocks), "shielded" landing pad? I've searched but not found anything yet. Not really worried about keeping it compact; plenty of space in the truck to just keep it in there and haul it around.
Hmmm...if I threw a rubber floor mat on the roof, would that work? (I don't have any rubber floor mats, just carpet, or I would have tried that by now.)
Thoughts? Thanks!
Actually, it’s a characteristic of a flux gate compass. They occasionally need recalibration to the Earth’s magnetic field, which also changes between locations. That’s why you have to do that stupid drone dance if you travel very far between take-off zones.
Your truck is made of iron which throws off the Earth’s magnetic field a bit around it and effects your compass, the same way that taking off from concrete with rebar in it sometimes does the same thing. It has nothing to do with EMI, it’s a magnetic field issue and a mat won’t help. You just have to be far enough away from your truck and other iron objects for that effect to be minimized.
Although it sounds like it might, compass calibration doesn't actually do anything to the compass.
That's a complete myth we can thank DJI for putting into their manuals years ago.
Fortunately that have dropped it nowdays.
Compass calibration has nothing to do with where on earth you are flying.
You can take your drone halfway round the world and fly without any need to recalibrate anything.
The link I put in post #18 explains what compass calibration actually does and why it's not necessary for travelling any distance.
Good info, thanks for posting it! I also have a flux gate compass (magnetometer) on my boat and calibrating it (to the boat) is fun - you have to steer in a S-shaped course to do it.
Remember when ship compasses had these for calibration?
David H
