Essentially new to this and excited to get started! (Austin, TX)
SublimeEnts
Texas
Hi all!
I'm from the Austin, TX area and have just gotten started flying. I have a Mavic 3 Pro, but started off by flying a friend's Mini 3 Pro.
Here's the best video I got with the mini: 3s interval, 5s video of the sunrise over a nearby lake. I accidentally touched the sticks, so it didn't stay perfectly framed:
Welcome to the forum!
What's your experience in this field?
It always sucks when the first post is a lost it or it crashed. :rolleyes: 👌
Rod..
Welcome to the forum! :)
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live Texas, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mavic 3 Pro, including the User Manual.
Fly On and Fly Safe…
Thank you for the long and thoughtful post.
I got my TRUST as soon as I knew I wanted to buy a drone, registered it before I even took it out of the package, and am about 30% of the way through the Pilot Institute course already, so it seems I'm off to a good start.
Thankfully the Mavic 3 Pro has a gimbal cover that must be removed in order to unfold the drone, so I don't have to worry about leaving it on accidentally. My friend with the Mini 3 Pro mentioned the same issue.
The only issue I've had flying so far is that the initial stick configuration was unintuitive to me. I changed the left stick to fore/aft and roll and the right stick to climb/descend and yaw and now have very few issues. If I could reverse the right stick's elevation controls, then it'd feel perfectly natural to me.
I hadn't thought about putting my phone number on the drone! That's a great idea! I added my registration number and figured that was enough. Now that you've gotten me thinking, I realize it really wouldn't be. Thanks for that advice!
Seems like you are off to a Great Start. I am a Pilot Institute Alumni (aced the exam 100%) so I have only great things to say about PI and the course by Greg Reverdiau…
Since you have already been on the FAADroneZone to register your drone, go back on and get a few authorizations to fly in restricted airspace like at Austin Executive Airport (not LAANC enabled…) it's good practice, not in the zero altitude areas, just the restricted altitude areas. Also get use to requesting LAANC at Austin-Bergstrom International. Not to worry, they do not hold you to it…
I use the DroneUp App and Windy.com for almost all of my flying, B4UFly and UAVForcast are good, but not as good…
As for changing the Flight Control Modes, practice, practice, and practice, you need those movements to be Second Nature, Muscle Memory, AND…
DO NOT let a Friend try your Drone without a carful warning that your controls are not standard…
I know you are flying the Pro, but Greg also offers a FREE Deep Dive Course on the Mavic 3 and it is really comprehensive on setting up and using the Mav 3…
Now, go have fun, and thanks for the feedback.
LT Signing Off..
DayTrip
