FAA reg sticker
Steel63
Florida
Hello everyone i have a question about my FAA sticker I'm a recreational flyer i have my phone# on my registration. is that a good idea or not ?
Ok i have a wetsuit on my drone so i put the sticker on the back left arm it has my FAA #and phone # no name thanks for your comment
Hey this might help. I got a custom made water slide decal for my drone. They give you enough to fit all your drones if you are using your drone for non 107 flight. Also they give you battery decals. Check out drone-retriever. com
Reactions: Steel63
I just use a sharpie.
Just write your registration number and phone number on the arms.
I think it's a great idea if losing your drone is a possibility. Without a phone number, the finder will likely have no way to contact you.
Reactions: Steel63
Labels are easier to remove than a sharpie. Could be good or could be bad??‍♂️. In any event, I think a phone number on the drone is good for responsible pilots.
FYI Rubbing alcohol removes sharpie.
deepdark
