FCC mode on Mavic 2 Pro possible?
Remember... to be sure that FCC is enabled, when you are in the camera view minimize the app and then maximize it back. Enjoy! :)
After this it still works fine. I have to make a testflight for the final verification, but for the moment it looks good.
By the way: There are exist a workaround to skip the 500m-limitation?
Chris
Need help again.
Now it doesn't work anymore... :(
I can start the app, the window open for about 0.5s and then close immediately. The App is still active in the tasklist, but I can't open it. After restart the app and the iPad the same.
Any hints? Reinstall?
Thanks in advance.
Chris
Need help again.
Thanks in advance.
Chris
It's olls valid for seven days, then you have to delete it and install again
Kind regards Thomas
Reactions: Chris_LSZO
Is it possible that the seven days trial period has expired? In this case you have to resign (reinstall) the app (every week!) or to join the Apple Developer Program (at about 100$ per year)
just close the app as tho you going to switch to other app... do not I repeat do not shutdown the app
jwright17
