First flight/Aloft Air Control Questions
TheCaptain
Illinois
Took the Air 2s and RC Pro out for their first flight. Have Air Control installed on the RC Pro. LAANC approval was simple, got through the checklists and Air Control wouldn't connect to the aircraft. I flew with DJI Fly.
After the flight, none of the DJI logs will sync to Air Control. Came home and have poked around the apps for 2 hours, can't get Air Control to connect nor sync....
I intend to fly with DJI, and in the future use DroneLink.
I was hoping Air Control was a simple one-stop for at least LAANC and logs. It didn't work how I've expected. What am I missing to have these work together?
1 - check your RC Pro is connected to WIFI (either phone hotspot or home wifi). Swipe down on the screen and click on the WIFI symbol. If its new equipment you'll have to connect to the wifi and put in yr passwords.
2 - you should be logged into your DJI account (settings/profile I think on the RC Pro
That's all good...Rc Pro has uploaded logs to the DJI cloud. I can use Air Control on any device, but the 2 apps aren't syncing to each other...
JeffN
