flight data
Here's your flight log:
DJI Flight Log Viewer - PhantomHelp.com
It shows the wind was too strong for your Mavic to make it back home. It ended up automatically landing (as designed) out in the sea when the battery reached the critically low level.
when it was 87 feet up pressed the rth but nothing from the controller
It doesn't work pressing RTH when the wind is too strong for the aircraft even to hold position, let alone RTH. Look at the computed wind speeds that you were flying in:
And the actual wind field is here:
That flight was doomed from the moment you took off.
flo1710
